dropped fox
Old 06-24-2008, 10:18 AM
HACKGT350
HACKGT350's Avatar
Default RE: dropped fox
you can still fit a good size DR under there with out raising it back up. get a set of 15" wheels and do a 26" tire thats all you are really gunna want a 28 will slow you down
HACKGT350 is offline
Old 06-24-2008, 11:28 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
If you are looking for pretty much a drag car, go for the drag springs that have the bag in the passenger rear corner. I know BBK has a set. I don't know if anyone else has. I believe they still have a drop to them from stock but I don't think it is as much as what you have already. And like Hack said, go with a smaller wheel and put some DR's on them. No reason to put a set on those 17's. It would be cheaper too.
projectresto83 is offline
Old 06-24-2008, 02:28 PM
Projectquick
Projectquick's Avatar
I planned on getting 15" weld rims for a set of 275/50R15s, but I really wanted to jack the back up to get some proper geometry back for my LCAs, lowerd like it is will sacrifice some traction even with the control arms on there. I'm looking to be cutting 1.7-1.8 60 foot times.
Projectquick is offline
Old 06-24-2008, 02:31 PM
projectresto83
M.A.D. Motorsports
Get some adjustable LCA's if your that worried about the geometry of the rear end. Get the right strut/shock combo and you will be just fine.
Old 06-24-2008, 02:37 PM
Projectquick
I guess it'll be okay, I'll try it with the set up now and if the numbers aren't what I'm looking for then I'lltry tinkering with it to see if I can get better 60's.
88 orangepeel notch
10-05-2015 09:03 AM
ChampInSD
10-02-2015 04:55 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
RCS02v6
09-29-2015 01:46 PM
Quick Reply: dropped fox
