intake install
Old 06-23-2008, 04:34 PM
ponyboy88
ponyboy88's Avatar
Default intake install
ok, so in a hurry to get my car back on the road, ordered an new intake and tb and egr spacer from later model and had it shipped next day air (cost me 140.00) and had some questions
am i going to have to pull the water pump or distributor to remove the lower intake, or is it just a matter of removing upper, then fuel rails and injectors and then the lower, and then the reverse
thanks
ponyboy88 is offline
Old 06-23-2008, 04:57 PM
droptop302
droptop302's Avatar
Default RE: intake install
You can even leav the dizzy in. Water pump stays in you will not need to take it out. Just upper lower and what ever is on the upper and lower goes on the new one
droptop302 is offline
Old 06-23-2008, 05:01 PM
5pointslow91
5pointslow91's Avatar
i wasnt able to leave the dizzy in wen i did my lower manifold
5pointslow91 is offline
Old 06-23-2008, 05:11 PM
droptop302
droptop302's Avatar
I have put a dozen intakes in mustangs stock and after market never took out the dizzy. The top cap and bottom part of the cap i did take off
Old 06-23-2008, 05:12 PM
redpony88
redpony88's Avatar
dont worry about the water pump. but you may or may not have to pull the dizzy, sometimes you can wiggle it out but you may have to pull it. if you do just make sure you stab it right again, check the tech article on how to do it if you dont know how to make sure it's right. but other than that, just pull the upper, the fuelrails and injectors and you should be good
redpony88 is offline
Old 06-24-2008, 08:41 AM
ponyboy88
ponyboy88's Avatar
thanks, hate having her off the road
djbigskrilla
09-20-2022 01:04 AM
Granatelli Sales
01-20-2020 12:34 AM
cbird1177711
09-02-2015 04:12 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: intake install
