timing marks
RE: timing marks
ok i went out wiped it down and sprayed it with cleaner and still nothing. bumped it looked around the whole thing....nothing. there is a chunk missing out of it but it looks like it was cast this way and the engine still runs fine. any thoughts ideas?
RE: timing marks
The numbers and marks are very small. Rust may have made it hard to read.
One mark that is definate and easy to find is TDC. As long as you can find that and have a dial back advance light you can set your timing without the small marks.
RE: timing marks
Mine was the same way. I had to sand it down completely to where the outside was shiney. It took quite a bit until I could see the numbers.
It's possible that your balancer doesn't have them, but this would be the first case I've ever even heard of where they're not on one. [&:] Try sanding the outside rim until it's shiney.
mungodrums
10-07-2015 04:01 AM
09-08-2015 11:50 AM
