HELP! 5.0 won't start
Old 06-30-2008, 08:11 PM
blackfox6886
blackfox6886's Avatar
Default HELP! 5.0 won't start
i have a 92 5.0 that turns over but, won't start. its getting spark and its got good fuel pressure, but the injectors arent spraying. i also had advance auto check the ignition module and its good. what else should i check? any help is appreciated.
thanks in advance
blackfox6886 is offline
Old 06-30-2008, 08:22 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: HELP! 5.0 won't start
how do you know the injectors aren't pulsing??? will it fire off ether??
mjr46 is offline
Old 06-30-2008, 08:26 PM
blackfox6886
we plugged a node( i think its how you call it) into the injector plug in and didnt get anyhting
Old 06-30-2008, 08:27 PM
mjr46
mjr46's Avatar
a noid light..okay if you had the tfi module tested and it's good how did you verify spark??
mjr46 is offline
Old 06-30-2008, 08:35 PM
blackfox6886
plugged in a spark plug type thing( not sure what its called)into one of the plug wires. my dad did that
Old 06-30-2008, 08:38 PM
mjr46
mjr46's Avatar
squirt some spray start in the tb and see if it fires up briefly
mjr46 is offline
Old 06-30-2008, 08:40 PM
1988TTOP
1988TTOP's Avatar
fuel pressure reg bad
1988TTOP is offline
Old 06-30-2008, 08:54 PM
blackfox6886
Default RE: HELP! 5.0 wont start
a few days ago it fired up but, instantly dies, and hasnt done it again.
Old 06-30-2008, 08:57 PM
1988TTOP
1988TTOP's Avatar
mine did that and i replaced the fuel pressure reg and run great after
1988TTOP is offline
Old 06-30-2008, 09:00 PM
blackfox6886
is there any way to check it b4 and buy 1
Quick Reply: HELP! 5.0 won't start
