Is a phenolic spacer really worth any gains? (GT-40)
Im finished porting my cobra cast GT-40 manifold, cleaned it out over and over, and im about to put it on. The question i have is weither or not a phenolic spacer will actually give me any power? They are only $65 at summit which is right down the street, should i get one? I know they are used to keep heat transfer down from the rest of the motor to the upper intake, but will it boost power? Thanks!
RE: Is a phenolic spacer really worth any gains? (GT-40)
Not really used so much to gain power as they are to help certain setups clear the valve covers. You may gain a little bit of torque but nothing your going to really notice. Keep in mind, if you go with a spacer and you have the stock hood, there's a good chance it won't clear.
wish I had read this last week then.
I am replacing my GT intake with a ported cobra and figured that if I didn't I would always wonder "what if"? I really wish it had been mentioned somewhere in my research that I needed an EGR spacer as well so that I could have been done already.
My intake stays quite a bit cooler after the spacer than it did without it. Mine doesn't clear the stock hood, but i'm still using it, so I have a little dent where the front bolt hits. I'm using a 1" spacer though with the explorer intake. I have a friend that's using one with a cobra intake & clears the hood fine.
My egr is no longer working & the coolant lines on the spacer have been blocked. Even after both my intake was cooler after the spacer.
As for any gains... I noticed nothing special, but I just have a filter in the engine bay collecting warm air. May have helped if I ran my intake ducting into the fenderwell instead.
Just my .02
Just my .02
if u get a 1/2inch or smaller it will clear a stock hood. i did not believe in them before my intake came with one and when i went to the track my lower intake would be too hot to touch and the upper was rom temp or cooler. i was very surprised. if keeps a lot of heat out of the upper intake
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
