need help please
need help please
ok went to set my timing cause it never ran right since the mods (mods below). the dizzy was set on 22 and it would run rich for the first five minutes after startup, so i set the dizzy at 14-16 now it goes down the road rich, you can just about hear the unspent fuel bubbling in the exhaust. i need help bad??
any help is appreciated, richard
mods:
bbk open air intake
80mm maf sensor (supposedly calibrated for 24# injectors)
75mm summitt throttle body
24# injectors
msd coil, cap, and wires
do i need a 90 computer, what's wrong? if there's something you think i need please let me know, and a resource to get it would be great!!
thanks, richard
if you're like me and don't like typing just call 573-578-5792
mods:
bbk open air intake
24# injectors
thanks, richard
RE: need help please
MJR46 THAT'S WHAT YOU TOLD ME A WEEK AGO FOR THE SAME PROB, I WASN'T BORN YESTERDAYI DO TROUBLESHOOT BEFORE I GET ON HERE AND A COUPLE WEEKS AGO I GAVE YOU THE CODES AND YOU DIDN'T HELP ME FROM THERE SO THANKS BUT NO THANKS AND WHOEVER SENT ME THE BASE IDLE PM, THANKYOU
ORIGINAL: fordlover79
when you set your timing, did you pull out the SPOUT connector?
~22° sounds about right for a 94-95 at idle with the spout in
I WASN'T TRYING TO BE SHORT WITH YOU I'M JUST FED UP WITH THIS THING. YOU ASK ME TO RUN A KOEO AND HELL EVERY CODE IN THE BOOK SHOWS UP, BUT WITH ADJUSTMENTS I HAVE WEANED ALL THE CODES OUT AND SHHHH THE PLUG WAS IN I DIDN'T SEE IT EARLIER BUT 1 HOUR AGO I SEEN IT ON THE RIGHT FENDER, SO I RECHECKED IT REAL QUICK AND IT'S DEAD ON 16 WHERE I WANT IT. I DROVE IT FOR ABOUT 5 MIN EARLIER AND WHEN I GOT HOME IT SEEMED LIKE THE THROTTLE WAS 10 TIMES AS SNAPPY SO I'M GOING TO DO A BASE IDLE AND RESET MY TPS AND HOPEFULLY MY COMP WILL LEARN FROM THERE. AND BY THE WAY THANK YOU FOR YOU'RE CONTINUED SUPPORT AFTER I WAS AN ***. MY GREATEST APPOLIGIES, RICHARD
