Need help with ring and pinion
Old 08-03-2008, 03:40 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Need help with ring and pinion
ORIGINAL: 8banger
ORIGINAL: Joel5.0
You will need a pinion gauge minimum........
Works great..you'll also need a dial caliper(cheap one 20 .00 bucks ) to measure the distance with using the tool..
only if he's not using ford gears and the pinion depth is stamped on pinion
mjr46 is offline
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
DJ Piner
09-30-2015 03:03 PM
Quick Reply: Need help with ring and pinion
