clutch problems help
was driving my car tonight... was shifting fine... then my clutch pedal got real soft... and my clutch quit working... if i push it to the floor it will work but not enogh to do anything.. it still rolls.... is there anyway i can adjust it? the clutch always grabbed good no signs or warnings of going out...Help would be greatly appreciated
RE: clutch problems help
tried it i could here it click but only when i push the clutch down... it helped alittle but still tried to roll forward.... so i guess it is the cable... are some cables better than others?
gtpcoupe is right about this. MAKE SURE you get aluminum quadrant. I had the same problems you were having, 3 times in 2 years before i finally got fed up and looked into and found out it's a known issue, that they put a crappy plastic quadrant in at the factories back then. I had to go to a ford racing dealer that was about an hour drive but worth it. No problems ever since.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
