Headlight Issues
Old 08-13-2008, 12:34 PM
calomino
calomino's Avatar
Default Headlight Issues
I have an 89 gt. Only the drivers side headlight,fog light and marker lights work. Pass side headlight real dim. I installed new headlight switch with new harness and still nothing. No turn signals or high beams either and I replaced turn signal assembly also... please help...thanx
calomino is offline
Old 08-13-2008, 04:07 PM
Blckstng93
Blckstng93's Avatar
Sounds like a bad bulb if everything else is working. I believe itll be a 9004 model bulb. There is a black collar behind the headlight. Turn it and the bulb can be pulled out.
Blckstng93 is offline
Old 08-13-2008, 04:22 PM
Blckstng93
Blckstng93's Avatar
Oops, i missed that. So you have no turns or high beams on either side? Im a bit confused at whats working and what isnt.
Drivers headlight - works
Drivers turn - ?
Drivers marker - works
Drivers fog - works
Pass headlight - dim
Pass turn - ?
Pass marker - ?
Pass fog - ?
Sounds more like a wiring issue. A well worn wire wont carry current like it used to.
Old 08-15-2008, 11:49 AM
calomino
calomino's Avatar
Default headlights
dr headlight works
dr fog light works
dr marker works
no dr turn signal
pass headlight dim (goes completly off when i turn fogs on,dr stays on)
pass fog light does not work
pass marker works
no pass turn signal
i replaced turn signal assembly with brand new one, new headlight switch, new headlight switch harness, new fog light harness....
calomino is offline
Old 08-15-2008, 02:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you may have a bad ground or a bad socket or shorted bulb and possibly a bad flasher relay..I don't believe all the problem s are related you may have more than one issue at hand
mjr46 is offline
Old 08-16-2008, 08:40 AM
calomino
calomino's Avatar
Default headlight issues
where would the ground for the headlights be located?
calomino is offline
cr620
10-03-2022 10:18 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Headlight Issues
