Motor/head Identification
Old 08-19-2008, 04:18 PM
mattdel
mattdel's Avatar
Default Motor/head Identification
So I think the previous owner lied to me a couple times...
How can I tell the difference between an E7 and E6? If it helps, there is a stamped 5 on the corner of the heads.
Also is there anyone here who can identify the year of the block for me, if I provided the numbers
mattdel is offline
Old 08-19-2008, 05:29 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
put the numbers up for the block and only real way to tell difference on heads would be to pull them and look at casting numbers and cumbustion chambers
mjr46 is offline
Old 08-19-2008, 06:04 PM
USMC1775
USMC1775's Avatar
There are ways to tell if you have the casting numbers, heres a set of E7s
This is the underside, you cant see this unless you remove it, or remove the intake and get a small mirror or something..
This "T" is under the valve cover
USMC1775 is offline
Old 09-01-2008, 07:25 PM
neverhit
neverhit's Avatar
Why did they put E7T's ( truck headers) on these engines? According to the codes, it belongs in the truck family.
neverhit is offline
Old 09-01-2008, 07:40 PM
USMC1775
USMC1775's Avatar
Because they wanted us to spend more money buying better heads
USMC1775 is offline
7_Zero
4 Cylinder NA and Turbo
05-08-2008 08:13 PM
b16sir1991
04-26-2007 01:23 PM
byronstyle
02-09-2007 12:41 PM
byronstyle
02-09-2007 12:59 AM
devins
15
03-06-2003 08:08 PM
Quick Reply: Motor/head Identification
