just got a 87
Old 08-23-2008, 09:05 PM
SalikDDD
SalikDDD's Avatar
Default just got a 87
just picked me up an 87 ALL STOCK with 121k on it, no smoke, no noises etc. thank god.
what are some things i should look at or check before i start tearing into it?
i plan on going with my GT40 heads, maybe a GT40 intake, e or f cam, longtubes - and running maybe a wet 100 shot on it, anyone think it will hold up or?
SalikDDD is offline
Old 08-23-2008, 10:16 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
yes but if it's speed density still I'd look into a maf conversion
mjr46 is offline
Old 08-23-2008, 11:58 PM
SalikDDD
SalikDDD's Avatar
i'm thinking of going to a carb setup on it since it's most likely speed density ( id on't pick up the car for another few days) already got the intake manifold, and carb but what else do i have to swap over? i got a regulator but it's for a non return setup and iw as wondering if theres any way i can cap off the return line from the tank and run a new inlet line all the way up to a mechanical pump or what..
also for the distributor, how do i get that thing firing, since i'll have to use an older distributor from my 67 302 original (new though) how do i get the coil firing and all that jazz? also do i leave the computer in or take it out?
SalikDDD is offline
Old 08-24-2008, 12:41 AM
ctgreddy
ctgreddy's Avatar
leave the computer in so you can still use ur pwr accessories, cruise, things liek that. the motor should hold up to that shot just fine as long as its installed right. and if your going carb you'd have to get a 6al ignition or one of that sort and a diff style coil(i think) and that will feed the dizzy.
ctgreddy is offline
Old 08-24-2008, 08:59 AM
mjr46
mjr46's Avatar
depending on your budget if you want to go cheap you'll need the duraspark ignition set up from an 85 = dizzy , coil and box, or if budget is of no concern msd all the way and if you don't want to run a return cap it off at the tank and just remove the ecm and harness = not necessary for operation of sub systems on the car
mjr46 is offline
Old 08-24-2008, 11:28 AM
KING OF THE STREET
KING OF THE STREET's Avatar
if your going with carborated thego with like a 150 175 shot i have a 150 in my stock stang they eat it up
KING OF THE STREET is offline
Old 08-24-2008, 12:48 PM
SalikDDD
SalikDDD's Avatar
ok well, i have an old 4.6 MAF from my 98 that i plan on using for the maf conversion, so i'll need an ECU right? what's the best one to get, 89? or what? someone said A9L but what is that, cus i'm confused
SalikDDD is offline
Old 08-24-2008, 04:57 PM
86HOGT
86HOGT's Avatar
Sounds like yo uneed to make up your mind..
98 MAF I don't think will work...idk...
86HOGT is offline
Old 08-24-2008, 05:23 PM
SalikDDD
SalikDDD's Avatar
not really - i can do either or i just was going for the easiest that's all. :\
SalikDDD is offline
