auto vs manual
auto vs manual
i do have a AOD and as much as id like a stick sometimes i just couldnt pass up the deal on my stang. i believe the car would feel alot faster with a 5spd but im curious to know how much a difference in acceleration.
its not huge but there is certainly a difference. If you want to swap go for it, there are tons of kits out there.
There are also many ways to give the slushy AOD some kick. Do the valve body, torque converter, etc and it will make a HUGE difference.... or you can do a C4 or a built AOD w/ a reverse manual VB or something of that sort... there are many options.
A manual transmission will run faster than an automatic, however an automatic will be much more consistent. If you're doing bracket racing of any sory this will be a key factor in winning and losing races. I have an AOD and am very happy with that. As said before there are ways to improve an AOD such as a torque converter and all that good stuff. The best way I've found to run an AOD is by leaving it in D. It will shift at 5,000 rpms on it's own. You could also manually shift through the gears in an AOD using the AOD shuffle which will allow you to hold 2nd gear.
just asking... you said there are kits out there for a aod to manual swap... mind if I ask where? or just point me to a company... been lookin but haven't really found anything worth while... sorry for posting a question on yours foxbod90
