wont start help!
Old 11-03-2008, 08:04 PM
Bullitt91
Bullitt91's Avatar
Exclamation wont start help!
since my tranny had been making all sorts of noise shifting i have parked it and got a beater... i went to start my stang yesterday and the battery was dead. i charged the battery and started it. it ran ok for a few min and then it started to run like ****, backfired a few times and quit then wouldnt start again. this was at night and i had my hood light unplugged so i could see if any of my wires were arching...well i found a plug wire arching on my ac line and my MSD blaster coil was throwing sparks everywhere! i tried to fire it up again after i put another coil on it but it would just crank nothing else...fuel pump relay wouldnt come on wot relay wouldnt come on. All the dash lights were ok execpt for the cel. it was really dim. i took the cover off my fuel pump relay and pressed the plunger down and my pump came on i tried to start it and it did run while i had my finger on the relay. i quit for the day and came out the next evening and now it just cranks even when it has fuel. wtf is going on?
Bullitt91 is offline
Old 11-03-2008, 08:46 PM
Bullitt91
Bullitt91's Avatar
i tried another computer with the same results. anyone have an idea?
Old 11-03-2008, 08:52 PM
IEATZ28GT
IEATZ28GT's Avatar
im kinda having the same problem but with out all the sparking and stuff i have fuel but no spark and i had my ignition box tested(good) and i just replaced my voltage regulator
IEATZ28GT is offline
Old 11-03-2008, 09:13 PM
Bullitt91
Bullitt91's Avatar
any of your relays dead?
Old 11-03-2008, 09:14 PM
IEATZ28GT
IEATZ28GT's Avatar
no the nutral safety relay maybe but other than that nothing else
Old 11-04-2008, 09:23 PM
Bullitt91
Bullitt91's Avatar
sometimes i have to throw it in N to start but that doesnt explain my problem now.. thanks.. anyone else have any info? im dyin here lol
Old 11-04-2008, 09:27 PM
bagellord
bagellord's Avatar
Do you actually have spark, you should be getting fuel, but are you getting compression? Could bad gas be causing all this or could the pump/pump relay be messed up?
bagellord is offline
Old 11-04-2008, 09:33 PM
Bullitt91
Bullitt91's Avatar
i replaced the pump relay but the problem is that none of my relays are powering up and i do have spark.
Old 11-05-2008, 10:29 PM
Bullitt91
Bullitt91's Avatar
anyone else? im really stumped here
Old 11-06-2008, 07:35 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
so why don't you stop throwing parts at it and properly troubleshoot it???...first grab a can of spray start and spray a little in the TB....does it briefly fire up???...if so you have a fuel system prob....I assume the battery is fully charged?? cranks fast but won't start right??.......anyway if it fires on ether, test for fuel pressure, if none, grab a test light and check for power at the relay under the seat = fp relay , you should have power to the pump from relay briefly when key is switched on and while cranking, if none you need to make sure the ecm is seeing a PIP signal from the tfi and commanding the windings in on the relay to engauge the relay.....make sure you have no blown fuses either, you should have power on one of the heavier wires to the fp relay at rest =koeo.....and power on one of the smaller wires for the relay windings, ecm controls the ground side of the windings....
mjr46 is offline
Quick Reply: wont start help!
