Need To Know Belt Size For No Smog Pump And AC
Old 05-28-2005, 11:32 PM
Quik
Quik's Avatar
Default RE: Need To Know Belt Size For No Smog Pump And AC
read the captions, it says for underdrives not stock pullied
Quik is offline
Old 05-29-2005, 12:01 AM
settled4automatic
settled4automatic's Avatar
ORIGINAL: ohsoquik02
i READ the captions. this guy hasn't said that he has underdrives, so i'm telling him that your picture won't work for him. so read your own damn captions before posting a picture that won't help the thread starter.
settled4automatic is offline
Old 05-29-2005, 03:10 PM
Chris C
Chris C's Avatar
Since this comes up so much could one of the mods make this a sticky?
Chris C is offline
Old 05-30-2005, 12:08 PM
tomabram
tomabram's Avatar
ORIGINAL: settled4automatic
Actually you should read again. It says for FOX body. Must be different than your 95. I bypassed the smog with the 84.5" belt with STOCK pullies. Works PERFECT!! So YES, it wil definetly work.
tomabram is offline
Old 05-30-2005, 03:04 PM
86HOGT
86HOGT's Avatar
Alright, guys, with stock pullies, and a 84 1/4" inch belt I routed my belt like this...
Now every car is different so belt sizes are going to differ a bit.
Also, no I didn't relocate the PS pump to where the A/C was, it's still in the stock position.
Finally, there's no problems with the belt flying off at high RPMs, due to the routing with the tensioner.
86HOGT is offline
Old 05-30-2005, 06:18 PM
LOVEMY88GT
I ♥ Acer
LOVEMY88GT's Avatar
Alright well i still have all the stock pullies and running a 85" belt with that same pattern. I need to know what is it doing if i dont have underdrive pullies??? I am having a problem starting up the car once it is warmed up and i shut it off. Is this the problem??? I also still have the EGR stuff still on the car. I removed the Smog Pump, Plugged the pipe to the heads, closed the smog pump line pipe to the h-pipe (professionally done at a shop), and plugged up all the vaccumm lines to the smog pump. How bad is all of this?? THANKS!!!
LOVEMY88GT is offline
09-10-2015 11:46 AM
09-09-2015 10:30 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 05:21 PM
Quick Reply: Need To Know Belt Size For No Smog Pump And AC
