installing front springs
Old 12-25-2008, 07:49 PM
symonds86
symonds86's Avatar
Default installing front springs
in swapping in my 96 spindles and i let the pressure down with a jack but i hit the handle and let the spring out. now i cant get it in i i even tryed compressors but they wont fit cause the compressors get in the way. any tips?
symonds86 is offline
Old 12-25-2008, 08:37 PM
5.0stanger
5.0stanger's Avatar
I unbolted the control arm at the frame and jacked into place
5.0stanger is offline
Old 12-25-2008, 08:49 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
2 man job. Need a big prybar. Set the spring in place in the upper perch. At the bottom of the spring, wedge the prybar in the front bottom of the coil. Have someone start jacking the control arm up while you keep force on the spring. It's tough to do, but it works.
PRO50SC is offline
Old 12-25-2008, 09:08 PM
Hamutoff
Hamutoff's Avatar
I may have it wrong, but cant you get the A arm to move so much to the point that it will actually point straight down at the ground... I just tore a 87 thunderbird apart & while taking the entier k member out I unbolted top of strut and anti sway bar and the a-arm moved down out of the way and the stock springs came out with zero compression, zero force... I imagiane that I could very easily place them back in then start pumping up the hydraulic jack... (out of direct line of fire of the spring of couse) It seems to me that its a one man job that way, does this jive?
Hamutoff is offline
Old 12-25-2008, 09:11 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Originally Posted by Hamutoff
I may have it wrong, but cant you get the A arm to move so much to the point that it will actually point straight down at the ground... I just tore a 87 thunderbird apart taking the entier k member out fully assembled... I unbolted top of strut and anti sway bar and the a-arm moved out of the way and the stock springs came out with zero compression, zero force... I imagiane that I could very easily place them back in then start pumping up the hydraulic jack... (out of direct line of fire of the spring of couse) It seems to me that its a one man job that way, does this jive
No, it has to be done like I described otherwise the spring just pops out.
PRO50SC is offline
Old 12-25-2008, 09:36 PM
Hamutoff
Hamutoff's Avatar
oh when jacking it back up the spring will try to escape then? If so is this also the case with shorter aftermarket springs? Could it be a 1 man job
Hamutoff is offline
Old 12-25-2008, 10:14 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
you have compressors and you still cant do it? i have drag launches which are 5 inches taller than stockers and i got them by myself. are you messin with stock spring, lowering, or drag launches? if its stock or lowering you should be able to just shove it back into its perch and jack it back into place without an issue.
FivePointOhh is offline
Old 12-25-2008, 11:19 PM
15austin
15austin's Avatar
Heres how I did it 3 weeks ago by myself (stock v8 springs with 3/4 coil cut out). I left the strut bolted up, unbolted the a-arm from the frame, used 2 jacks on each part of the a arm where it bolts up to the frame, jack up both jacks at the same time till I could get the bolts back in.
I had the same problem, spring always poped out of the a-arm. I have no compressor.
15austin is offline
Old 12-25-2008, 11:37 PM
crusin92red5.0
crusin92red5.0's Avatar
it could be a one man job or a two man job. i did it by myself and believe me i was pissed and tired after doing it. one hand holding the pry bar in place with pressure and one hand pumping up the jack, but its tough.
crusin92red5.0 is offline
Old 12-26-2008, 07:52 AM
symonds86
symonds86's Avatar
ok thanks guys, its just one of those things that sounds simple, but really pisses ya off after a few tries i'll try yer suggestions
Quick Reply: installing front springs
