suspension question
suspension question
Hey guys my 89 lx ran a best of 12.86 @ 113 with totally stock suspension with bfg drag radials. Not even subframes. lol So my question is how much faster would it go with subframes, drag launch springs, starange 10 way shocks and struts and new control arms? I have all it all waiting to install! Thanks in advance!
Following mods:
tfs twisted wedge heads
tfs stage 1 cam
tfs track heat intake
mac shorty headers
mac x pipe
mac mufflers with crome tail pipes
3.73 gears
pro 5.0 shifter
msd wires, cap & rotor
msd coil
black magic extreme electric fan
bbk fuel pressure regulator
30lb svo injectors
73mm c&l mass air meter
70mm bbk throttle body
center force dual friction clutch
march a/c delete
underdrive pulleys
egr deleted and no emissions
Following mods:
tfs stage 1 cam
mac shorty headers
mac x pipe
3.73 gears
pro 5.0 shifter
msd coil
30lb svo injectors
march a/c delete
underdrive pulleys
Well, it's not going to instantly make you go faster, but I would assume you could drop your 0-60 by a decent bit! The real test would be to get used to the suspension and how high rpm you can drop it at and get the perfect launch!
I have UPR agj uppers and solid lowers. B-4 with my stock suspension I have some IMCA dirt track tires and with 10psi I could dump my clutch at 4K and it would barely spin I would get about 1.8 60ft. Now with the exact same tires with 15psi I dump it on the rev limiter (6250) and it will dead hook. It hooked so good that I have to slip the clutch slightly to get rolling. I get high 1.6 60ft.
You need to get sumframes in yesterday. I put mine on when it ran 14s.
09-08-2015 11:50 AM
