Starter Solenoid question
Old 01-02-2009, 03:52 PM
kurazee
kurazee's Avatar
Default Starter Solenoid question
Probably a really stupid question here... I messed up the wires to my starter solenoid and need some help. Looking at the battery from the drivers side, which side of the solenoid do the wires go? Do any of them go on the same side as the positive battery cable? I have tried a couple of different ways without luck. When I connect the battery cables the starter wants to crank. Tx
kurazee is offline
Old 01-02-2009, 04:03 PM
Hung Like a Stang
Hung Like a Stang's Avatar
I needed the same thing,
here you go:
https://mustangforums.com/forum/5-0-...-the-noid.html
Hung Like a Stang is offline
Old 01-02-2009, 04:26 PM
kurazee
kurazee's Avatar
Tx...exactly what I needed, however, I now have a different question. Does it matter which post on the starter that the big wire goes to? Also, I have 2 wires coming up from my starter, is the smaller one a ground? Tx
kurazee is offline
Old 01-02-2009, 05:09 PM
ALMOST STOCK
ALMOST STOCK's Avatar
If you have 2 wires to the starter you'll need to follow this diagram then.
Courtesy of jrichker
ALMOST STOCK is offline
Old 01-02-2009, 06:09 PM
kurazee
kurazee's Avatar
Tx...almost ready for its first fire!
kurazee is offline
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
logan409
09-26-2015 07:43 PM
Quick Reply: Starter Solenoid question
