Power Steering Hell
Old 01-10-2009, 03:31 PM
Catchpole
Catchpole's Avatar
Default Power Steering Hell
I've replaced the pump and the pressure hose of my power steering pump now and I noticed that it had been whining a little much around corners, so I went to bleed the system and after turning it to lock a couple times I noticed there was a big puddle underneath the driverside mount of the rack/where all the hoses go into the rack. It don't think it's the fittings, as they don't look wet.
iS this an indicator that my rack is also bad now? The car had been run for quite a while without steering fluid due to a leak.
Catchpole is offline
Old 01-10-2009, 04:10 PM
1988TTOP
1988TTOP's Avatar
it could be just the bellows
1988TTOP is offline
Old 01-10-2009, 08:21 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
when replacing or reinstalling the hoses that go into the rack there is a small and a slightly larger nylon thin sealing washer that goes on each hose end fitting they are white, call ford and they will know what you need
mjr46 is offline
Old 01-10-2009, 09:45 PM
Catchpole
Catchpole's Avatar
What are those?
I'll definately give that a go
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
Quick Reply: Power Steering Hell
