You set the timing to 36 with the spout out and ran it like that? Did you just initially check your timing or did you completly reset it? It backfires out the exhaust right?
the computer will not adjust the timing curve under a load with the spout out. essentially you will be running your base timing throughout your entire RPM band, which obviously is not a good idea.
Mine ran like that at 14 degrees for the longest time because I couldn't get the vac advance to function properly and I didn't have any problems. But EFI is a little more sensitive I guess too
What dizzy do you have in there? Drop in another one and see what happpens.
Hell try pulling that one out and restabbing it from scratch.
I had a weird problem with mine awhile back that caused it to back fire some and I just pulled it and reset the timing.
stock reman dizzy from napa, and if the dizzy were the problem wouldnt you think it would still be happening?
