Coolant System Restoration
It don't look hard, but looks can be deceiving.
I was wondering what all it would entail. I filled up the overflow tank to the cold fill line about a month ago, and today the low coolant light popped on. It's time for some surgery, folks.
I found a crack in the top of my overflow tank, and I know there's a leak in the gasket(s) where the water pump is bolted to the block. I figured I might as well replace the hoses, as well.
Can anyone provide me with a mini-guide from start to finish? I'm a fart smeller, er, smart feller and I'll most likely pick up on it really quick once I get going. I mean, crap, can replacing some hoses, a couple gaskets and a tank be /that/ hard?
Waterpump removal is pretty much how it looks you cant really mess it up unless a bolt breaks.For that reason i suggest if this motor has been together a while you replace the bolts its cheap insurance.
As for a flush the easiest way i could think of would be one of those low buck kits by prestone from an auto parts store.
Hows the radiator and heater core lines?
Cool deal. I didn't think there'd be any suprises. Do I need to buy the part-specific bolts, or can I just match them at a hardware store? Is there anything I should use to help back the bolts out? It looks like a brand-spanking-new pump, so I'd imagine that the bolts haven't been set for too long.
I only know there's a crack in the overflow tank and a gasket is leaking. I'm just replacing all the hoses for ease of mind.
Thanks for the info, all.
EDIT: I forgot...How much torque for tightening the bolts back down?
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
