HELP HELP HELP! new OIL PUMP installed
Old 01-29-2009, 10:52 PM
92FOX
92FOX's Avatar
COIL IS SNAPED Proper!!!! , Firing Order is right! Starter Fluid didn't work!, I dont hear Sound from fuel pump ? Maybe that is broke? but it's new 255 Walboro less then 300 mile on it but car has been sitting?
92FOX is offline
Old 01-29-2009, 11:00 PM
1988TTOP
1988TTOP's Avatar
if sparyin starting fuild in didnt work then it is properly spark related
1988TTOP is offline
Old 01-29-2009, 11:03 PM
brentloftis
brentloftis's Avatar
Well, it should have partially started with the ether (spray start), back to the first question, are you sure the distributor is correct? If the timing is off it won't start. Was the car running before you did the oil pump or is this the ground level of a project?
brentloftis is offline
Old 01-30-2009, 12:37 AM
Night Terror
Night Terror's Avatar
5$ says he stabbed the distributer wrong...
when you put the distributer back in... did you do just throw it in or get piston 1 to TDC and all that jazz?
Night Terror is offline
Old 01-30-2009, 07:21 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Originally Posted by 92FOX
i have one of those elecronic tester in a kit? , Be more specific i never tested spark or fuel dont even know what to do ?
So you can put an oil pump in but don't know how to check for spark and fuel?
PRO50SC is offline
Old 01-30-2009, 09:06 AM
Portmaster
Portmaster's Avatar
You need to be a lot more specific about what you did and how. Did you pull the engine or do the pump in car? Did you pull the distributor of not. How long has the car been sitting? Was the dist exposed to the weather? It could be as simple as moisture in the cap. Spray some WD-40 in the cap and try it again. Be specific
Portmaster is offline
Old 01-30-2009, 05:54 PM
93 LX FiveO
93 LX FiveO's Avatar
i was about to ask who did the work cause i can guarantee 92Fox didn't...
93 LX FiveO is offline
Old 01-30-2009, 09:31 PM
mustangsneverdie
mustangsneverdie's Avatar
my ques. is did you put the oil pump drive shaft in especially if you can't check for fuel or spark
mustangsneverdie is offline
Old 01-30-2009, 09:42 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Want to know something funny about that subject?
http://www.youtube.com/watch?v=yR4pyFB9zCo
No oil pressure there.......didn't know the driveshaft for the pump wasn't in...... neither one of us built the motor....shoulda checked but didn't......but the motor is still in (or was as of 2 weeks ago) and ran great! I love fords!
projectresto83 is offline
Old 01-30-2009, 10:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
this thread= funny
mjr46 is offline
Quick Reply: HELP HELP HELP! new OIL PUMP installed
