FInally got the car started.... but it runs like crap!
Old 02-07-2009, 10:35 AM
kweb288
kweb288's Avatar
Default FInally got the car started.... but it runs like crap!
Ok so i just got done putting a NOVI 2000supercharger on my car, and am having major driving issues with it
Just got back from the very short test drive and these were my problems:
-searching for idle when not in gear 400-900 range
-BUCKS A LOT
-can not even get half on it with out it getting choppy and cutting out
any ideas and or help would be greatly appreciated
kweb288 is offline
Old 02-07-2009, 11:08 AM
kweb288
kweb288's Avatar
not positive but im pretty sure its back firing too/ not hitting on all cylinders, Do you think i shoould replace the plugs with a step colder ? and if so what kind and what gap
kweb288 is offline
Old 02-07-2009, 11:44 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
WHAT KINDA MASS AIR ARE YOU RUNNING??
mjr46 is offline
Old 02-07-2009, 11:47 AM
kweb288
kweb288's Avatar
its a 90mm lightning mass air from anderson ford motorsports with the loadio calibrator. It is clibrated for the 19#ers from before.
I pulled the #8 spark plug and the thing was comletely balck, and the hayness book said this is due to oil blow through...... any thoughts?
kweb288 is offline
Old 02-07-2009, 11:56 AM
mjr46
mjr46's Avatar
IF THE PROBLEM IS HAPPENING under load it could have spark blow out, a black sooty color is carbon fouled due to gas not oil, oil burning normally is deposited on the electrode as a ash colored substance
mjr46 is offline
Old 02-07-2009, 11:58 AM
kweb288
kweb288's Avatar
ok so how should i fix this? colder plug with a different gap?
kweb288 is offline
Old 02-07-2009, 12:13 PM
mjr46
mjr46's Avatar
if it is spark blow out , run a smaller gap, what gap are you running now??
mjr46 is offline
Old 02-07-2009, 04:53 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Could def be the mass air causing problems as well.Gap the plugs at .030 and run 2 steps colder.
PRO50SC is offline
Old 02-07-2009, 08:28 PM
kweb288
kweb288's Avatar
ok ya im running a .005 right now.
and why would the mass air cause problems by the way..........
kweb288 is offline
Old 02-07-2009, 08:47 PM
NoGo95GT
NoGo95GT's Avatar
You are probably having an air leak somewhere between the MAF and the throttle body. You need to get your plugs regapped to .028-.032. However this is not causing your poor drive-ability. I had the exact same problem. It turned out there was air leaking aft-the MAF.
NoGo95GT is offline
Quick Reply: FInally got the car started.... but it runs like crap!
