5.0L Twin Turbo KIT 5.0 Intercooled
http://cgi.ebay.com/ebaymotors/NEW-F...Q5fAccessories
looks pretty good would anyone suggest thins on a stock 302 block and can i just use one of the turbos instead of twin? how much psi is too much for a stock 302
I have a friend that runs 15 psi on a stock block on his single set ups. One was a 60mm and the other was 70mm. He has done it several times, but always seems to crack his blocks after time. He is running 15 psi right now on a stock block in front of a viper spec T56 Foxbody.
well thats the first ebay kit that ive seen that doesnt use 304 stainless so thats a plus. but the waste gates are external and i dont see anywhere on the manifolds to mount them. on top of that, there is no after turbo exhaust piping included so its all custom work on your part. it comes with 2 blow off valves but no where to mount them so thatll be custom as well. if you cant weld or bend pipes, that kit will end up costing you more then if you just went to b&g customs and bought a complete kit from them
They're probably SS Autochrome manifolds or something similar as well and if you've ever seen one of their turbo manifolds, you'd know that the only thing those hunks of junks are good for are door stops.
