Lifter ticking noise video...HELP!?!?!?
Old 03-04-2009, 10:36 PM
im_stuck_in_iraq
im_stuck_in_iraq's Avatar
Default Lifter ticking noise video...HELP!?!?!?
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/NyQrrvvqj0I&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/NyQrrvvqj0I&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
im_stuck_in_iraq is offline
Old 03-04-2009, 10:38 PM
im_stuck_in_iraq
Ok that didnt work but here is the link. You can kind of hear the ticking sound as you guys requested. I think the exhaust is to loud i will have to do another video outside the garage and then see.
http://www.youtube.com/watch?v=NyQrrvvqj0I
Old 03-04-2009, 11:35 PM
im_stuck_in_iraq
IDK you cant really hear it only if you listen close..kinda sh*tty vid..ill work on another one...
Old 03-04-2009, 11:37 PM
AdderMk2
Banned
AdderMk2's Avatar
probably hear it better if you put the camera IN the engine bay
AdderMk2 is offline
Old 03-04-2009, 11:46 PM
im_stuck_in_iraq
I have one of those too but you cant hear it hold up ill put that link up as well..
Old 03-05-2009, 12:00 AM
im_stuck_in_iraq
http://www.youtube.com/watch?v=hX4GhnSP2bI
*** another video *** idk still cant hear sh*t great...
Old 03-05-2009, 04:19 AM
BladeX10
BladeX10's Avatar
From what i can hear.. Its definitely not a knock. Sounds like a loose rocker arm.. Sounds very identical to my camaro when i had it. Never found out because the engine blew up.
I'd run alittle seafoam through the booster line. It might be a sticky lifter or something. Its not a knock so thats good news. :P
BladeX10 is offline
Old 03-05-2009, 10:08 AM
saleenpride1986
saleenpride1986's Avatar
Mine kinda does the same sound. I was told it was a rocker arm, but I tightened mine down to proper specs and it still made the same sound. Perhaps a lifter or maybe your rocker arms. It is sorta hard to tell in the vid over the sound of the exhaust and vids never do true justice to anything.
saleenpride1986 is offline
Old 03-05-2009, 10:35 AM
86 5.0L
86 5.0L's Avatar
or a more common header leak
86 5.0L is offline
Old 03-05-2009, 01:10 PM
im_stuck_in_iraq
ill take it outside and take another video
Quick Reply: Lifter ticking noise video...HELP!?!?!?
