bad sounds (video)
#21
use a 1/4" deep socket on the end of a high speed reversable drill and prime the oil pump while you have a valve cover off... im betting you arent getting oil flow to the top end and you probably have a collapsed lifter, or two-sixteen
#23
take the dizzy out, put the oil pump priming rod on the oil pump shaft, hook it up to a drill and run it in reverse on the drill for about 3-5 minutes or until you have a good consistant flow out of ALL the push rods
