sunroof
Old 03-16-2009, 12:48 PM
rdmypny
rdmypny's Avatar
Default sunroof
does the stock sunroof glass come completely out or just pop up?
rdmypny is offline
Old 03-16-2009, 01:29 PM
ponyboy302
ponyboy302's Avatar
it comes completely out .. once its lifted you squeeze the hinges together and it should come loose then you lift the glass and pull towards the back of the car .. there are two tabs fitted into slots and itll just slide out ..
ponyboy302 is offline
Old 03-16-2009, 04:30 PM
rdmypny
rdmypny's Avatar
ok thanks do you have problems with it leaking?
rdmypny is offline
Old 03-16-2009, 05:17 PM
ALMOST STOCK
ALMOST STOCK's Avatar
Have you tried tightening the 2 Phillips headed bolts on the inside beside the handle that go through the glass to the flat retainer on the outside of the glass yet?
ALMOST STOCK is offline
Old 03-16-2009, 08:04 PM
rdmypny
rdmypny's Avatar
no but i did find that the tube are not draining and some idiot siliconed the 2 back holes up and i pulled one of the front hoses off from the inside and it poured water all over me so i think i am gonna use an air compressor to blow in the tubes the might be stopped up by dirt dobbers.
rdmypny is offline
Old 03-16-2009, 08:05 PM
rdmypny
rdmypny's Avatar
also i just checked the 2 bolts they wiggle around in the glass but the botls are tight. what do i do about that?
rdmypny is offline
Old 03-16-2009, 08:38 PM
ALMOST STOCK
The front drain holes exit the car behind the front wheel where the back of the splash pan has a square place on it. The rear drain holes exit through a hole at the front of the rear tire in the GT ground effects.
With the bolts being tight they might be rusted in the retainer (the flat piece on the outside of the glass) in the shelves of the retainer, so thast you're not able to tighten them. Or you might be able to add another vinyl washer to take up some of the slack if you can back the bolts out.
Old 03-16-2009, 11:09 PM
im_stuck_in_iraq
im_stuck_in_iraq's Avatar
wish i had a sun roof! Must be NICE...
im_stuck_in_iraq is offline
Old 03-17-2009, 04:47 PM
rdmypny
rdmypny's Avatar
ok thanks that helps allot.
rdmypny is offline
AZ Redfire
07-23-2011 07:44 PM
floydfan
06-29-2005 07:31 PM
cool66
03-22-2005 01:27 PM
Mortl24
02-21-2005 11:29 PM
kkspeed
08-04-2004 02:41 PM
Quick Reply: sunroof
