5.0 Idle goes up and down help !
Hello Guys,
As everybody knows the weather has been nice around last week in Toronto so I took my girl out of the cold winter garage and I found that my Idle is not steady, it goes rev up and down all the time, any ideas what I should look for ? I guess it is a vacuum but I am not sure, there is too many Vac hoses in the bay.
Please help and thanks for your comments!
IBM
IBM
If you think it's a vacuum leak you can take carb cleaner and spray it around area's where gaskets are. If the idle changes when you spray in a certain area then there's a leak of some sort. Another thing would be to clean the mass air and make sure the TPS / IAC are in their proper settings.
Do you have any mods or are you completely stock, because having mods can add to changing the idle.
As far as I know it is stock, I got her 3 years ago, always store her and when I take her out never had any problems before, this time I put a full gas tank but I did put any stabilizer on her. I just put a full tank and a stp injector cleaner but no diference, still the same. How do I check the TPS / IAC are in their proper settings as you said ?
