car wont start
Old 03-25-2009, 06:23 PM
90notch3
90notch3's Avatar
Default car wont start
worked on the car today and im ready to fire it up, its a 90 4cyl to v8 swap. the injectors are not firing, the ground on the back of the motor is hooked to the intake manifold, and i can only gett a reading of .02 on the tps. what could be wrong?
90notch3 is offline
Old 03-25-2009, 07:05 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
how do you know the injectores are not firing??
mjr46 is offline
Old 03-25-2009, 07:16 PM
90notch3
90notch3's Avatar
noid light
90notch3 is offline
Old 03-25-2009, 07:18 PM
mjr46
mjr46's Avatar
do you have spark??
mjr46 is offline
Old 03-25-2009, 07:23 PM
90notch3
90notch3's Avatar
yes i used a spark tester on the #1
90notch3 is offline
Old 03-25-2009, 07:27 PM
mjr46
mjr46's Avatar
do you have current on one of the two wires on an inj plug, ecm controls ground usually
mjr46 is offline
Old 03-25-2009, 07:30 PM
90notch3
90notch3's Avatar
yes i put a test light on the red wire and it lit up
90notch3 is offline
Old 03-25-2009, 07:33 PM
mjr46
mjr46's Avatar
what year harness and is it maf or SD
mjr46 is offline
Old 03-25-2009, 07:39 PM
90notch3
90notch3's Avatar
its a 1990 maf harness, im not sure of the injector harness year tho but i read u can use any year for that....
90notch3 is offline
Old 03-25-2009, 08:35 PM
mjr46
mjr46's Avatar
once ecm sees a pip signal generated from the stator in the dizzy, then ecm knows car is cranking and to power fuel pump up and pulse injectors, do you hear the pump come on when you turn the key to run briefly??
mjr46 is offline
Quick Reply: car wont start
