still wont start
still wont start
this is a 93 gt with a 5 speed swap.
i jumped the clutch switch and the only way i can get the car to start is by jumping it, it wont turn over if i turn the key...
any suggestions?
ignition switch? somthing i did wrong is the auto to 5speed swap?
any suggestions?
what are you "jumping" to get the car started.
If you have to jump the switch, then you need a new switch. if you have to jump the battery, you might have a bad battery, or a bad terminal
if you are jumping the solenoid, it may be bad, but check for 12v+ at the signal wires from the ignition before condemning it
on the AOD on the left hand side where the shift linkage hooked there was a switch with an electrical 4 pin connector on it, 2 wires are for starter lock out = car must be in park or in nuetral for starter operation to work and the other two wires went to the back up lights, for ease the two wires for starter operation I just made a jumper wire up on the harness side to connect the two together, which makes it so it'll start in gear, some don't like that idea so they wire those two up to the clutch switch which is a normally open switch and closed upon pedal depression
