piston ring gap?
piston ring gap?
I was just wondering what gap you guys run top and bottom. how much benefit have you guys notcied from individually gapping them?....also what ring grinder are you using?...I have a machine shop to my disposal so im thinking of making my own.
Depends on the piston, type of rings, intended use for the engine. I have a Sunnen electric but I end up using my Powerhouse manual hand crank unit most of the time. I made a stand from a 12 inch brake rotor and piece of roll bar tubing. I just slide it over close and fit the rings. I have no idea how much differance in performance because I won't build a performance engine with anything but file fit rings
like said it depends on pistons used ring manufacture but also on if you are gone to run a power adder and what kind of fuel you are gone to burn. I just use a summit ring grinder with a hand crank.
Again it all depends on the piston (Forged, Hyper?, How it will be used (Street, Race, Superchaged, Nitrous?) Tell me exactly what you have Piston make and material, How it will be driven (Street, Race) What type of fuel (Gas, Race Gas,etc) Exact bore size (prob 4.030) and then I can give you a piston ring end gap.
its going to be a 347 NA, with a small 75 shot(for giggles), pump gas, its going to be a very, very aggressive street car which will probably see some life at the track but it wont live there. 4.030 bore, forged pistons,crank,rods.
I really like the sound of going with a .020-.024 gap. I read somewhere that for the second ring they go with a bigger gap becasue sometimes the ring is cast and it will allow it to expand a little more. I am not quite sure though the reasoning exactly why you would want a bigger gap on the top. high rpms and expansion?
