Tech question, see pic
Old 03-30-2009, 07:41 PM
mighty90
mighty90's Avatar
Default Tech question, see pic
See pic, Please advise...
mighty90 is offline
Old 03-30-2009, 07:46 PM
mustangsneverdie
mustangsneverdie's Avatar
where does it lead to?
mustangsneverdie is offline
Old 03-30-2009, 07:52 PM
mighty90
mighty90's Avatar
Again I am shrugging, but I am planning to scream and run.
Seriously though, when it gets back from the shop I'll follow it.
mighty90 is offline
Old 03-30-2009, 08:00 PM
mustangsneverdie
is there anything running under it?
Old 03-30-2009, 08:06 PM
5.0stanger
5.0stanger's Avatar
The thing on the left is a FMU, By the mounting bracket I see near the alternator, you musta had a supercharger on it at one time.
The other thing is a proportioning valve, you have rear disk?
5.0stanger is offline
Old 03-30-2009, 08:08 PM
mighty90
mighty90's Avatar
With a zoom, I see two hoses going to underneath the engine and a vacuum line disappearing behind the intake. I'll prop it up and get a look under it. I've been scratching my brain trying to figure out what that thing does. I wonder if its why its running so bad. Hrmmm....
mighty90 is offline
AdderMk2
Banned
AdderMk2's Avatar
that goes to the supercharger system that you DONT have anymore
AdderMk2 is offline
Old 03-30-2009, 08:11 PM
5.0stanger
5.0stanger's Avatar
I also see you have 24lb injectors and what seems to be a stock MAF...not good either. I bet with a FMU, the wrong injectors and MAF combo it runs real bad.
Old 03-30-2009, 08:12 PM
mighty90
mighty90's Avatar
Hallelujah, PRAISE JEBUS!! I love you man!!! I love you, now.....what the heck is an FMU?? Is was for the supercharger? Maybe The nos? Y
es all wheel discs, I dunno why the guy who modded it chose to go all wheel disc on four lugs, but he did. Finding the brake pads for the rear has been a pain in the tush.
mighty90 is offline
Old 03-30-2009, 08:16 PM
5.0stanger
5.0stanger's Avatar
The FMU (fuel management unit) will increase fuel pressure under boost. I believe without boost it isn't hurting you...but I am not sure. I think you can disconnect it and just run the manifold vacuum to the original FPR.
The rear disk 4 lug is probably off and svo mustang or a turbo coupe....you should be able to do a google on those and find some infor for brake parts.
Quick Reply: Tech question, see pic
