351 cleveland in 88 foxbody what is needed
Old 04-07-2009, 02:10 PM
82bossblack
82bossblack's Avatar
Default 351 cleveland in 88 foxbody what is needed
hi i have a 88 notch back mustang and i am going to make it my race car it had a 4 cylinder in it. but i am going to drop a a 1969 cleveland in it and i want to no what i will have to change. thanks
82bossblack is offline
Old 04-07-2009, 02:14 PM
Portmaster
Portmaster's Avatar
Your plan
Portmaster is offline
Old 04-07-2009, 03:34 PM
Gary H
Gary H's Avatar
Do some searches, there are swap kits out there. I think D&D makes one. If you cant find one I'll loo tomorrow...
Gary H is offline
Old 04-07-2009, 03:40 PM
worm2500
worm2500's Avatar
i have heard of this being done before but i personally do not know anyone who has done this swap. it is alot more common for people to drop windsors in than clevelands. if you want to go big block i recommend the 460. portmaster is right you should change your plan.
portmaster check your PM's
worm2500 is offline
Old 04-07-2009, 03:41 PM
Gary H
Gary H's Avatar
http://www.ddautospec.com/products_engineswap.html
Gary H is offline
Old 04-07-2009, 03:43 PM
mstngsule68
mstngsule68's Avatar
Originally Posted by worm2500
i have heard of this being done before but i personally do not know anyone who has done this swap. it is alot more common for people to drop windsors in than clevelands. if you want to go big block i recommend the 460. portmaster is right you should change your plan. im not even sure anyone makes swap headers for a cleveland.
clevelands arnt big blocks
mstngsule68 is offline
Old 04-08-2009, 09:22 AM
Ford Drag Team
Ford Drag Team's Avatar
Clevelands were introduced in late 1969, however they carried a 1970 part # on the block which is #D0AE, so it cannot be a 1969 Cleveland technically.
Check the # on your block to be sure.
But headers and an oil pan/pickup tube will be the major components that you'll need if you decide to drop it in.
You can use a 1975-up 351M,400, or 460 Duraspark distributor if you decide to go with an electronic ignition as opposed to the old points style distributor.
Ford Drag Team is offline
Old 04-08-2009, 09:37 AM
wildcobrar
wildcobrar's Avatar
The swap is super simple. The Cleveland is a small block. 302 engine mounts bolt right up as does a 302 tranny. Swap headers and a swap oil pan(just as needed with a Windsor) and you are good to go.
Joe
wildcobrar is offline
Old 04-08-2009, 09:39 AM
Ford Drag Team
And a 28oz flywheel...
Old 04-08-2009, 09:55 AM
wildcobrar
wildcobrar's Avatar
I agree! The Windsor too!
Joe
Quick Reply: 351 cleveland in 88 foxbody what is needed
