Replacing Manifold gaskets
Old 04-09-2009, 05:05 PM
  #21
ryan_89_mustang
ryan_89_mustang's Avatar
18020 is the only number I have.
ryan_89_mustang is offline
Old 04-09-2009, 05:07 PM
  #22
mstngsule68
mstngsule68's Avatar
who makes it?
mstngsule68 is offline
Old 04-09-2009, 05:42 PM
  #23
5pointslow91
5pointslow91's Avatar
the last bolt n the back on the passenger side was the only 1 that gave me trouble, had to get it under the car w mini turns
5pointslow91 is offline
Old 04-09-2009, 05:58 PM
  #24
ryan_89_mustang
Yeah I never had any problem getting the bolts out but then I realized I didn't know what way the gaskets went. Anyone know for sure?
Old 04-09-2009, 05:59 PM
  #25
ryan_89_mustang
Originally Posted by mstngsule68
who makes it?
It is some parts store brand I don't recall.
Old 04-09-2009, 06:42 PM
  #26
mstngsule68
the softer part will go on the side the header is atleast thats the most sensible way
Old 04-09-2009, 09:30 PM
  #27
ryan_89_mustang
Alright I guess I will try it that way then.
Old 04-09-2009, 10:13 PM
  #28
Mustangkiler
Mustangkiler's Avatar
softer side is too the header, hope you have better luck than me
Mustangkiler is offline
Old 04-09-2009, 10:47 PM
  #29
mstngsule68
like i said the way i did it, tighten them all down starting from the middle make sure u evenly torque them. then just keep doing it till there pretty damn snug, with a small wrench dont use like a 30" breaker bar, then when they all are, start it up and keep going around and tightening them, then once they all wont go anymore and the car is fully warm, turn it off, come back a hour or so later when its all cooled, start it up, and keep tightening, once fully warm, shut it off, do that 2/3times, i used a small about the size of my hand wrench cuz i have aftermarket smaller head bolts "7/16th", do that and u should be all set.
Old 05-12-2009, 08:16 AM
  #30
84conversion50
84conversion50's Avatar
Originally Posted by AdderMk2
remove all the center bolts and loosen the last two up a good amount. you should be able to pop the gasket out with a screw driver.
the new one just drops in place..
and I recommend these!
http://cgi.ebay.com/ebaymotors/LOCKI...ayphotohosting
you dont have to scrape them?
84conversion50 is offline
Quick Reply: Replacing Manifold gaskets
