motor mount questions
Old 04-08-2009, 03:30 PM
worm2500
worm2500's Avatar
Default motor mount questions
what kind of mounts would you guys use on a 600HP engine.
worm2500 is offline
Old 04-08-2009, 03:51 PM
worm2500
worm2500's Avatar
will these work or should i go with solid mounts? this is also for a 351W
http://store.summitracing.com/partde...5&autoview=sku
worm2500 is offline
Old 04-08-2009, 04:01 PM
jwog666
jwog666's Avatar
those are lifetime warranty the looks of it. i would go with those.
jwog666 is offline
Old 04-08-2009, 06:20 PM
AdderMk2
Banned
AdderMk2's Avatar
prothane's will work.. I run solid mounts on my 347
AdderMk2 is offline
Old 04-08-2009, 06:49 PM
symonds86
symonds86's Avatar
adder you used solid motor mounts and a stock tranny mount right?
symonds86 is offline
Old 04-08-2009, 09:47 PM
uedlose
uedlose's Avatar
I would run no less then a poly mount, but I think I would run a solid mount IMO
uedlose is offline
Old 04-08-2009, 09:49 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
solids will be your best bet or poly but they may experience breakage also if you plan to race it alot
mjr46 is offline
Old 04-08-2009, 10:02 PM
AdderMk2
Banned
AdderMk2's Avatar
yes i do
*edit* scratch that.... i was just under the car and apparently I have a poly mount now...
I forgot that I swapped that from the spare trans I bought 3 years ago
AdderMk2 is offline
Old 04-09-2009, 03:05 PM
worm2500
worm2500's Avatar
anyone got these
worm2500 is offline
Old 04-09-2009, 03:47 PM
uedlose
uedlose's Avatar
I have a friend that had them mounts and something was strange about them and he could not use them. I have been using the type that are common on E-bay
uedlose is offline
Quick Reply: motor mount questions
