94GT With Rough Idle + Codes!
My newly purchased 94GT is suffering from a rough idle. the car doesnt seem to run bad when im driving it, but it idles like crap and it also crank a few times before it starts. while running every now and then the engine will "stutter". I recently changed these parts:
cap and rotor
spark plugs
spark plug wires
new air filter
Tonight I hooked up a fuel pressure gauge and with the Key On, but the engine not running the fuel pressure was: 37PSI and steady. It didnt leak down at all.
with the key on and engine running the fuel pressure was stead at 32psi at idle and went up each blip of the throttle.
I tried pulling codes and the ones i got were: 116 and 314.
Since there is plenty of fuel can i rule out: regulator, fuel filter and fuel pump? Could a faulty ignition coil cause this? the car seems to be running rich.
Thanks in advance!
cap and rotor
spark plugs
spark plug wires
new air filter
Thanks in advance!
okay will do. But even if i were moving the timing slowly and watching the engine -- wouldnt i see the idel smooth out. The stutter is there no matter where the timing is. I also got the ECT (116) code. Does anyone know if the ECT sensor being bad will affect idle and a/f ratios?
