Oil Cooler or High Volume Oil Pump, NOT BOTH?
I read somewhere to either run an oil cooler or a high volume oil pump...not both, but it did not really explain why. I can only guess that it makes the pump push oil through all the hoses and strains it? The engine I bought came with a high vol. pump. It has been in for around 11 years and has around 5000 miles. About a year ago, I installed an oil cooler because I thought it would help, but I don't know if it is doing any good and I don't want to cause any damage if indeed having both is not good. Can anyone explain why not to run both? I don't drive it very much so if the oiler cooler is better off, then I will do so.
Thanks for your help.
