ran a KOEO and KOEO test now what?
KOEO test
81 - Secondary Air Diverter Circuit Failure
82 - Secondary Air Bypass Circuit Failure
95 - Fuel Pump Circuit Open-PCM To Motor Ground
KOEO test
18 - Spark Out (SPOUT) Circuit Open (R), Loss Of Ignition Diagnostic Module Input To PCM/SPOUT Circuit Grounded (M)
91 - o2 Sensor Circuit Indicates Lean -driver side(R), No o2 Sensor Switching Detected. always lean -driver side(M), Shift Solenoid 1 Circuit Failure (O)
does anyone know how to fix any of these?
KOEO test
the pump is still there but there are no lines to the exhaust, there is a little sensor that goes to the carcoal box, should that still be hooked up? i assume the smog is the code 81 and 82 right?
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GT350 S550 Tech
09-29-2015 03:29 PM
