Water Temp Installation
I recently bought a water temp gauge and now i need step by step installation instructions to install ity on my 87 mustang 5.0. I also need help finding the water temp gauge sending unit. Any pics will be greatly appreciated.
Thanks
Thanks
It should come with good instructions, I've never heard of that brand before though so who knows. Find a good ground and a good switched 12v power source. I tapped into one of the wires on my headlight switch so when I turn on my headlights/instrument panel lights it would illuminate my gauges. Get out your multi-meter and start probing wires to find one that will work for you. Then just run the wire from the gauge, through the firewall, install your new sending unit in place of the stock one, tighten it down and attach the wire that goes to the gauge. It's really simple.
EY 92hatchlx you've made me decide to use your method of wiring the 12v to the headlights so how do I do the wiring? Do I look for the headlight wiring in the fuse box? It's my first time wiring gauges so I'm going to learn installing this one. So its not possible to just replace the old sender with the new one instead of wiring the gauge? Thank alot man.!
I know how to do enough basic wiring to get me by. I just probed the wires and found one that with the key on and the switch off gave me 0v and with the key on switch on gave me 12v. Pull your headlight switch off the cluster and there's some wires behind it. I just used splice connectors. Don't use the stock gauges, they're all crap.
