Ticking at WOT
Ticking at WOT
Whenever I floor it I hear a loud ticking rattle kind of sound coming from around my feet. Ive tightened the headers and downpipes but still hear it. Also my driver side downpipe was a little black around the flange. Does this sound like an exhaust leak? It only does it at WOT. If I drive normal(without flooring it) it sounds fine.
if you have black around the flange then yes you still might have a leak my car use to have a leak where header met with mid pipe and it sounded like if one of my lifters was bad a lot of ticking but mine would do it all the time maybe your leak only opens at wot cause engine moves
Well I checked today and its not detonation. My header bolts were a little loose but not much. Its weird though because it happens alot at WOT. Sometimes when the RPMs are around 1500 in OD when cruising and I press the gas to go up a hill you can hear it but once it shifts and the RPMs are higher I cant hear it. Is it my lifters? I think Im going to try some Risoline and see if that helps.
