Door lock key problems
2 issues...
1) Remote and door lock buttons work on the locks, but the Driver side door does not lock or unlock with the Key. It also won't open from the inside when locked. What's most likely causing this?
2) Also I think im having wiring problems since the driver side door used to only lock/unlock when the door is closed, and not while open (using the remote or switches).
Now it doesn't work at all. bad connection/wiring?
Seized power door lock actuator maybe. I had the one on my drivers door deactivated until I get around to replacing it. Sounds like you are having the exact same symptoms I had. Don't bother trying to get a used one, most are on the brink of seizing due to their age. If that is your problem just get a new one. You'll know it's on the outs when the lock button on the door begins to go up and down half the distance it used to and you have to hit the lock and unlock a few times to get it to do what you want it to. Eventually it won't move at all and the key won't work either...good luck.
2 issues...
How do I fix that? Is it as easy as removing the boot and taping up some frayed wires with electrical tape?
Ok, so I took off the door panel and had to manually twist part of the actuator to get it moving. Sprayed some WD-40 on it and got it moving again. I can now open and lock the door using the KEY. However the power lock switch and remote still does nothing on the driver side. I'm pretty sure it's a wiring problem, because before the power locks went, it would only work when the door was closed, but wouldn't work when the door was open...not even an inch.
this lock problem seemed to start shortly after getting the door hinges replaced at the shop a while back.
Anyone know how to go about checking it or can point me in the right direction?
