diff help
Old 05-16-2009, 08:53 PM
raftdaddy
raftdaddy's Avatar
Default diff help
i have a pretty much stock 93 lx and my 8.8 is making some rough noise.it is only on a right hand turn.i was wondering if you happen to know of a good axel and diff rebuild kit.all the kits are for gear changes.allso if you know what my problem might be it would be great.i live in northern canada so going to the corner parts store isn't much of an option,it's all order on line.in about a month i will be putting on a trf intake,afr 165,1.6 rr,24 lb inj,maf,cold air,and 70mm tb.juswst waiting for about a month,if that changes anything.i have an aod and frpp 3:73 right now.it was a slight whine last fall,parked it for the winter now it's rough,not torn up bearing rough but kinda metal friction sound and no leaking seals.sorry for choppy post,i'll get better.
raftdaddy is offline
Old 05-16-2009, 08:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if you've centralized the point of the noise pull the axles and start there by inspecting bearings and axle surface where bearing rides
mjr46 is offline
Old 05-17-2009, 10:49 AM
raftdaddy
raftdaddy's Avatar
Thumbs down
thanks for the reply,will tear into it and i'm sure i'll have questions.can you recommend a good web site?i order from latemodel restoration all the time but it seems like there is allways backorders on every order,they have a great selection but it's getting frustrating.
67LimeCoupe
09-30-2015 04:46 PM
Cavedawg
09-17-2015 09:51 AM
09-01-2015 08:16 PM
92 5.0stang
08-13-2015 06:46 AM
HYPEracing
10-31-2003 10:12 PM
Quick Reply: diff help
