misfiring still!??!?! help
Old 05-30-2009, 11:25 PM
Stangnsnow2
Stangnsnow2's Avatar
Exclamation misfiring still!??!?! help
ookay i have changed everything the next thing is to change my fuel filter even though i changed it last year. my car misfires/ hesitates and then kicks on all 8 cylinders but at wot it is fine. cruzing around is when i really notice the problem i did new wires plugs coil and cleaned my mass air meter and still cant find this problem...anything??????
Stangnsnow2 is offline
Old 05-31-2009, 09:41 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what about a cap and rotor??
mjr46 is offline
Old 05-31-2009, 09:24 PM
Stangnsnow2
yea new cap and rotor, i got a new msd distributor so it all came with it
Old 06-01-2009, 05:17 PM
PJC Racing
PJC Racing's Avatar
Post error, see following post.
PJC Racing is offline
Old 06-01-2009, 05:20 PM
PJC Racing
PJC Racing's Avatar
Have you pulled the codes? Is the car possibly running lean? I see you have a supercharger, what is the fuel supply system made up of besides 255 fump and adjustable regulator? How much pressure? How much boost?
Old 06-01-2009, 07:34 PM
mjr46
mjr46's Avatar
run a koer test as stated first, also make sure there are no vaccum leaks and all S/C tube clamps are on tight
mjr46 is offline
Old 06-02-2009, 09:42 PM
Stangnsnow2
ran a koeo and got 81 and 82 and the smog system isnt on the car besides the pump for the supercharger bracket
the koer test i got 94 and 44
Old 06-02-2009, 10:01 PM
Stangnsnow2
and i forgot i have code 95 from the koeo test, however the fuel pump turns on and off?
Old 06-02-2009, 10:04 PM
deaverj
deaverj's Avatar
i have a msd dizzy on my 5.0 and i have nothing but problems out of it at the moment one minute it will miss fire then you go wiggle the dizzy then it run nice and smooth for a bit then it gos back to miss firing
deaverj is offline
Old 06-02-2009, 10:10 PM
deaverj
deaverj's Avatar
deaverj is offline
Quick Reply: misfiring still!??!?! help
