How to troubleshoot Oil Pressure issues?
Old 05-31-2009, 11:52 AM
bbbngowc
bbbngowc's Avatar
Default How to troubleshoot Oil Pressure issues?
Yesterday I drove my car out and it drove no problems. Last night I went to drop my brother home and I noticed the oil pressure gauge stayed at zero. Never moved. This happened once before and I did a service and it went away. Now it's back! I checked the oil level and it's fine. How do I troubleshoot this thing?
bbbngowc is offline
Old 05-31-2009, 12:32 PM
zebo87
zebo87's Avatar
check all around the engine compartment and see if there is any oil in the engine bay or under the car. also check the oil pressure line that feed the gage. the most usual suspects are the distributor and the rear main seal.
zebo87 is offline
Old 05-31-2009, 12:54 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
for you the easiest thing to do would be replace the sending unit or run a manual /mech gauge and monitior the pressure that way, if it were in fact an internal engine issue you wouldn't get very far before kaput occured, sounds like a gauge or sending unit issue.
mjr46 is offline
Old 05-31-2009, 01:09 PM
bbbngowc
bbbngowc's Avatar
I checked all around and it doesn't seem to be any leaking. I changed the oil less than 2 months ago. I just started it up and (Lord have mercy) the engine sounds like it's knocking. I'm thinking it's the oil pump and I'm thinking it's not easy to change.
bbbngowc is offline
Old 05-31-2009, 01:11 PM
bbbngowc
bbbngowc's Avatar
What does the sending unit do?
bbbngowc is offline
Old 05-31-2009, 02:07 PM
ryan_89_mustang
ryan_89_mustang's Avatar
If it is already knocking then it is too late.
ryan_89_mustang is offline
Old 05-31-2009, 03:57 PM
bbbngowc
bbbngowc's Avatar
When I start it, I can hear a loud clattering noise, but it goes away after a few seconds. Is that engine knock?
bbbngowc is offline
Old 05-31-2009, 05:04 PM
67mustang302
67mustang302's Avatar
Depends on what the noise is caused by. The sender is basically the pressure sensor.
67mustang302 is offline
Old 05-31-2009, 05:10 PM
uedlose
uedlose's Avatar
you need to get a mechanical gauge on it to see if you have any press. but if you need to see now and don't have a mech. gauge you can take off the sending unit and crank it over a few sec. and see if you are getting any oil at all. if you are that don't mean that the press is right but at least you are getting some oil. if not don't start it any more and you will need to get the pan down to look at the pump and the pump drive shaft. then go from there.
uedlose is offline
Old 05-31-2009, 07:11 PM
mjr46
mjr46's Avatar
it measures the unit of pressure within the engines oiling system
mjr46 is offline
Quick Reply: How to troubleshoot Oil Pressure issues?
