alt bracket problem
That is the old style brackets before the serpentine belt system. If you look at the application tab on Summit's website it says for "V" belt drive. Unless you have changed your serpentine to V belt, it will not work.
http://summitracing.com/parts/TRD-94...tine|Year|1992
here it says that it works with the serp setup.. im just really confused
Wouldn't be the first time Summit is wrong. They are a great company with great customer service. I am sure they will take it back
Serpentine belt systems are tightened by using a tensioner pulley. With the one you bought it has that slotted bracket because you used to have to adjust the alt. and PS. individually. I am sure it looks nothing like what you have on your car right now.
March makes one for the 86 - 93 mustang serpentine belt, and uses a shaft with threaded rod ends to adust the tension. It replaces the bulky stock alternator/smog pump bracket.
http://summitracing.com/parts/MCH-1465/
stangin1996gt
09-21-2015 11:01 AM
09-17-2015 07:57 PM
09-16-2015 07:53 PM
