anybody tried this
Old 06-20-2009, 06:17 AM
flythe76
flythe76's Avatar
Default anybody tried this
was thinking of putting a 351c in a 84 hatchback.don't want to pay jegs price for a oil pan.78-79 f-150 4x4 came with 351m-400's and a rear sump oil pan. anybody know if it will work
flythe76 is offline
Old 06-20-2009, 09:11 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
A 351 CIN A FOX will have to be custom done, get the build right will be a chore as well as install, they don't make an install kit to do such
mjr46 is offline
Old 06-20-2009, 09:45 AM
87notch408
87notch408's Avatar
It is easily doable, you just have to be patient and not rush. I have seen one fox with a 351C in it and it was BAD!! I would think a tubular K member would be a logical first step to help with clearance. If you can weld, you can make the oil pan fit if it is a little off.
87notch408 is offline
Old 06-20-2009, 12:33 PM
wrenchturner75
wrenchturner75's Avatar
yes the 351m pan will work BUT it must be modified so if your not an expert welder dont attempt it, the 351c swap is cake hedman hustler has the headers that fit extremely well , i strongly suggest usin a swap pan then you can get the matching pickup also. the swap is not cheap to do the headers alone will rock you 600 bucks! yes there are other headers that can be made to work but again if you not a welder forget it. i recently completed my clevo swap and let me tell ya the power and rpm capability of these motors is awesome! if you need any more info just ask.
wrenchturner75 is offline
Old 06-21-2009, 08:06 AM
flythe76
flythe76's Avatar
thanks guys. i am a welder so that stuff is not a problem
flythe76 is offline
