Lots of smoke
Old 06-21-2009, 07:38 PM
yosfynest11190
yosfynest11190's Avatar
Default Lots of smoke
My car smokes all the time. Its blew smoke so i know its oil my question is what could be the cause of this? my motor does have a lot of miles on it so any ideas im new to the ford thing.
yosfynest11190 is offline
Old 06-21-2009, 07:41 PM
mustangsneverdie
mustangsneverdie's Avatar
rings, valve seal, pcv valve
mustangsneverdie is offline
Old 06-21-2009, 07:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what he said^^^^^
mjr46 is offline
Old 06-21-2009, 08:20 PM
yosfynest11190
im going to do the valve seals and pcv valve 1st and then see if it still does i plan on changing out the motor soon any way
Old 06-21-2009, 08:29 PM
mustangsneverdie
you will have to remove the valves to change the seals
Old 06-21-2009, 08:39 PM
yosfynest11190
sounds like some work i should just save up and change the heads at the same time to gt40's
Old 06-21-2009, 09:16 PM
Iroc
Iroc's Avatar
if it burns smoke only on startup then its your seals.
Iroc is offline
Old 06-21-2009, 10:52 PM
AdderMk2
Banned
AdderMk2's Avatar
pfft... no you dont
AdderMk2 is offline
Old 06-21-2009, 10:58 PM
mustangsneverdie
Originally Posted by AdderMk2
pfft... no you dont
O my bad op I thought you did but he's actually built more engines than me, listen to him
Old 06-21-2009, 11:47 PM
yosfynest11190
its smokes during driving and really doesn't stop. So i hope its not the rings unless im going to be planing for my engine sooner
Quick Reply: Lots of smoke
