i have a 87 coupe 5.0 here is my problem when i drive it, it will sputter through the gears like there is no power or gas to it i have replaced these parts so far timing chain, tps sensor, idle air sensor, fuel regulator, fuel filter, pick up coil in the distributor if you have any answers that might help i would be thankful
I HAVE A TWIN TURBO KIT ALSO SO I THINK I AM GOING TO GO WITH EITHER A 190LPH OR A 255LPH WITH 42LBS INJECTORS, AND YOU THINK THAT THE IGNITION COIL WOULD DO THAT TO THE CAR
STOCK 5.0 BUT HAS EAGLE RODS AND FORGED PISTONS, NONE ADJUSTABLE, SPARK PLUGS ARE NEW
SPARK PLUGS LOOK GOOD DONT NO GAP DONT HAVE A GAP MEASURE ITS ALL IN STORAGE
