Car wont start....
Old 08-25-2009, 05:12 PM
88BlueGT
88BlueGT's Avatar
Default Car wont start....
A few months back my starter was giving me some problems, wouldnt start on the first try, etc. Than after it did that every once in a while (for a few months) it just magically stopped doing that and was perfect..... all the way up til last week. All the sudden it wouldnt start and sounds like the starter went but it only has about 2k on it. Anyway, I took the starter off and had it checked and its fine. The starter never turns over just clicks once when I turn the key. Any help on what the hell this could be? I also tried jumping it from the solenoid to see if it was something in the ignition which its not. Could this possibly be the starter solenoid? but if it was the solenoid wouldn't nothing work in the car?
88BlueGT is offline
Old 08-25-2009, 05:21 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Could be either. Also, check all the connections are tight and clean.
PRO50SC is offline
Old 08-25-2009, 05:53 PM
88BlueGT
88BlueGT's Avatar
We'll if the solenoid was bad, would I even be able to get a click out of the starter?
88BlueGT is offline
Old 08-26-2009, 04:58 PM
88BlueGT
88BlueGT's Avatar
??? noone ???
88BlueGT is offline
Old 08-26-2009, 05:02 PM
mattdel
mattdel's Avatar
if the solenoid was truly bad the starter wouldn't click. if you have a test light and a buddy you can check it real easy. sounds to me like you have a bad cable somewhere in the loop, either the battery ground, or the solenoid to starter cable.
mattdel is offline
Old 08-27-2009, 01:03 AM
88BlueGT
88BlueGT's Avatar
yea I'm going to check the battery ground tomorrow and see if theres anything wrong there. I relocated the battery to the trunk and so thats where the grounds at, maybe it came loose or something :/ ill check it out tomorrow and post back w an update
88BlueGT is offline
djbigskrilla
09-20-2022 01:04 AM
chain
08-17-2015 08:52 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: Car wont start....
