Noise in the carb?
Old 09-02-2009, 04:45 PM
AntiRiceRacing
AntiRiceRacing's Avatar
Default Noise in the carb?
Just got my car running again today, there is a noise coming from the carb, it sounds like popping or like air coming out of the carb. The car is also running stupid rich, but aside from the noise and running rich it runs great. Should i invest in a new carb or what?
AntiRiceRacing is offline
Old 09-02-2009, 05:00 PM
mattdel
mattdel's Avatar
Depending on the circumstances, it could be a number of things.
Accelerator pump, vacuum advance, clogged metering jets...
mattdel is offline
Old 09-02-2009, 05:22 PM
AntiRiceRacing
I was going to get a video of the noise, but while it was running the timing light fell off the radiator no to some wire and the car turned off and now wont start. Good stuff.
Old 09-02-2009, 08:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
sounds like it may be lean, vaccum leak??
mjr46 is offline
Old 09-02-2009, 08:17 PM
AntiRiceRacing
There is only one vacuum line going from the carb to the dist. i think. I also think its running rich because it smells of nothing but gas and smokes a little. But it doesnt sputter or hesitate one bit, which is good. Ill probably be replacing the carb anyway because it looks old as *****.
Old 09-02-2009, 08:40 PM
mjr46
mjr46's Avatar
power valve might be blown out
mjr46 is offline
Old 09-02-2009, 09:04 PM
AntiRiceRacing
Nah, the power valve was ****ed on my old car, and it wouldnt rev over 2k, this one runs fine, but makes noise... hmm..
Old 09-02-2009, 11:02 PM
mjr46
mjr46's Avatar
HAVING A BAD POWER VALVE DOESN'T PRODUCE JUST ONE SYMPTOM OFTEN...........anyway check for vaccum leaks like a base plate to carb gasket and intake gaskets, I had one recently leaking right where the head meets intake
mjr46 is offline
Old 09-03-2009, 07:24 AM
AntiRiceRacing
There is a stud missing in the intake, so the carb is being held on by 3 nuts, ill try and get a video later today.
Old 09-03-2009, 11:45 AM
mjr46
mjr46's Avatar
so check to see if it's causing a vaccum leaK
mjr46 is offline
Quick Reply: Noise in the carb?
