ATF or Gear Oil?
ATF or Gear Oil?
Okay I got a Borg Warner 5 Speed transmission the only numbers I could find are these
13-52-066-919
the tag is missing from the transmission those are stamped in right under the shifter on the side
I need to know if I used ATF in it or Gear Oil?
13-52-066-919
A NON-WC T5 uses gear oil
a 85+ WC T5 use ATF
http://www.moderndriveline.com/Techn...t5_history.htm
http://www.5speeds.com/t5/
a 85+ WC T5 use ATF
ALL World Class T-5 use ATF oil and NOT heavy gear oil or Redline MTL! All NON-World Class T-5 use 70 wt gear oil.
Casting numbers on the side of the main case or extension housing CANNOT help you ID a transmission
How can you tell the difference between a WC T5 and a Non WC T5? I need to change my tranny fluid and I noticed when I put the motor and tranny back in the car a while back, ]it was filled with gear oil. I don't know if the previous owner put gear oil in it without realizing it needs ATF or if gear oil is right.
The Hayne's manual calls for the following
T50-D Mercon ATF
All others 80W gear oil
I just put a new clutch in my 90 GT and it had Borg Warner on it and I know for a fact it had gear oil in it and I know it was old so apparently it's not a T50-D
Duke
T50-D Mercon ATF
Duke
Well I know mine says Borg Warner on it but I know it had gear oil in it I don't know if its WC or NWC But since Gear Oil is what was in it then I guess that's what I'm going to put in it
